查看: 3204|回復(fù): 9
[已解決] 3.5手機(jī)論壇首頁,可以開N格么
62
6 點(diǎn)
發(fā)表于 2023-11-19 09:25:35 |廣西| 只看樓主 |倒序?yàn)g覽 |閱讀模式
類似這樣子,在公告下面添加
后臺開啟論壇首頁四格,然后打開template\你的模板\forum\discuz.htm(或者是discuz.php)刪掉下面代碼
  1. <!--{if !empty($_G['setting']['grid']['showgrid'])}-->
  2.                 <!-- index four grid -->
  3.                 <div class="fl bm">
  4.                         <div class="bm bmw cl">
  5.                                 <div id="category_grid" class="bm_c" >
  6.                                         <table cellspacing="0" cellpadding="0"><tr>
  7.                                         <!--{if !$_G['setting']['grid']['gridtype']}-->
  8.                                                 <td valign="top" class="category_l1">
  9.                                                         <div class="newimgbox">
  10.        <h4><span class="tit_newimg"></span>{lang latest_images}</h4>
  11.        <!--{if $_G['setting']['forumallowside']}-->
  12.        <!--{eval $slide_width = 220;}-->
  13.        <!--{else}-->
  14.        <!--{eval $slide_width = 278;}-->
  15.        <!--{/if}-->
  16.        <div class="module cl slidebox_grid" style="width:{$slide_width}px">
  17.        <script type="text/javascript">
  18.        var slideSpeed = 5000;
  19.        var slideImgsize = [{$slide_width},200];
  20.        var slideBorderColor = '{$_G['style']['specialborder']}';
  21.        var slideBgColor = '{$_G['style']['commonbg']}';
  22.        var slideImgs = new Array();
  23.        var slideImgLinks = new Array();
  24.        var slideImgTexts = new Array();
  25.        var slideSwitchColor = '{$_G['style']['tabletext']}';
  26.        var slideSwitchbgColor = '{$_G['style']['commonbg']}';
  27.        var slideSwitchHiColor = '{$_G['style']['specialborder']}';
  28.        {eval $k = 1;}
  29.        <!--{loop $grids['slide'] $stid $svalue}-->
  30.        slideImgs[<!--{echo $k}-->] = '$svalue[image]';
  31.        slideImgLinks[<!--{echo $k}-->] = '{$svalue[url]}';
  32.        slideImgTexts[<!--{echo $k}-->] = '$svalue[subject]';
  33.        {eval $k++;}
  34.        <!--{/loop}-->
  35.        </script>
  36.        <script language="javascript" type="text/javascript" src="{$_G[setting][jspath]}forum_slide.js?{VERHASH}"></script>
  37.        </div>
  38.                                                         </div>
  39.                                                 </td>
  40.                                         <!--{/if}-->
  41.                                         <td valign="top" class="category_l2">
  42.                                                 <div class="subjectbox">
  43.                                                         <h4><span class="tit_subject"></span>{lang collection_lastthread}</h4>
  44.                                                 <ul class="category_newlist">
  45.                                                         <!--{loop $grids['newthread'] $thread}-->
  46.                                                         <!--{if !$thread['forumstick'] && $thread['closed'] > 1 && ($thread['isgroup'] == 1 || $thread['fid'] != $_G['fid'])}-->
  47.        <!--{eval $thread['tid']=$thread['closed'];}-->
  48.        <!--{/if}-->
  49.        <li><a href="forum.php?mod=viewthread&tid=$thread[tid]&extra=$extra"{if $thread['highlight']} $thread['highlight']{/if}{if $_G['setting']['grid']['showtips']} tip="{lang title}: <strong>$thread[oldsubject]</strong><br/>{lang author}: $thread[author] ($thread[dateline])<br/>{lang show}/{lang reply}: $thread[views]/$thread[replies]" onmouseover="showTip(this)"{else} title="$thread[oldsubject]"{/if}{if $_G['setting']['grid']['targetblank']} target="_blank"{/if}>$thread[subject]</a></li>
  50.        <!--{/loop}-->
  51.                                                  </ul>
  52.                                          </div>
  53.                                         </td>
  54.                                         <td valign="top" class="category_l3">
  55.                                                 <div class="replaybox">
  56.                                                         <h4><span class="tit_replay"></span>{lang show_newthreads}</h4>
  57.                                                 <ul class="category_newlist">
  58.                                                         <!--{loop $grids['newreply'] $thread}-->
  59.                                                         <!--{if !$thread['forumstick'] && $thread['closed'] > 1 && ($thread['isgroup'] == 1 || $thread['fid'] != $_G['fid'])}-->
  60.        <!--{eval $thread['tid']=$thread['closed'];}-->
  61.        <!--{/if}-->
  62.        <li><a href="forum.php?mod=redirect&tid=$thread[tid]&goto=lastpost#lastpost"{if $thread['highlight']} $thread['highlight']{/if}{if $_G['setting']['grid']['showtips']}tip="{lang title}: <strong>$thread[oldsubject]</strong><br/>{lang author}: $thread[author] ($thread[dateline])<br/>{lang show}/{lang reply}: $thread[views]/$thread[replies]" onmouseover="showTip(this)"{else} title="$thread[oldsubject]"{/if}{if $_G['setting']['grid']['targetblank']} target="_blank"{/if}>$thread[subject]</a></li>
  63.        <!--{/loop}-->
  64.                                                  </ul>
  65.                                          </div>
  66.                                         </td>
  67.                                         <td valign="top" class="category_l3">
  68.                                                 <div class="hottiebox">
  69.                                                         <h4><span class="tit_hottie"></span>{lang hot_thread}</h4>
  70.                                                 <ul class="category_newlist">
  71.                                                         <!--{loop $grids['hot'] $thread}-->
  72.                                                         <!--{if !$thread['forumstick'] && $thread['closed'] > 1 && ($thread['isgroup'] == 1 || $thread['fid'] != $_G['fid'])}-->
  73.        <!--{eval $thread['tid']=$thread['closed'];}-->
  74.        <!--{/if}-->
  75.        <li><a href="forum.php?mod=viewthread&tid=$thread[tid]&extra=$extra"{if $thread['highlight']} $thread['highlight']{/if}{if $_G['setting']['grid']['showtips']} tip="{lang title}: <strong>$thread[oldsubject]</strong><br/>{lang author}: $thread[author] ($thread[dateline])<br/>{lang show}/{lang reply}: $thread[views]/$thread[replies]" onmouseover="showTip(this)"{else} title="$thread[oldsubject]"{/if}{if $_G['setting']['grid']['targetblank']} target="_blank"{/if}>$thread[subject]</a></li>
  76.        <!--{/loop}-->
  77.                                                  </ul>
  78.                                          </div>
  79.                                         </td>
  80.                                         <!--{if $_G['setting']['grid']['gridtype']}-->
  81.                                                 <td valign="top" class="category_l4">
  82.                                                         <div class="goodtiebox">
  83.        <h4><span class="tit_goodtie"></span>{lang post_digest_thread}</h4>
  84.        <ul class="category_newlist">
  85.        <!--{loop $grids['digest'] $thread}-->
  86.        <!--{if !$thread['forumstick'] && $thread['closed'] > 1 && ($thread['isgroup'] == 1 || $thread['fid'] != $_G['fid'])}-->
  87.        <!--{eval $thread['tid']=$thread['closed'];}-->
  88.        <!--{/if}-->
  89.        <li><a href="forum.php?mod=viewthread&tid=$thread[tid]&extra=$extra"{if $thread['highlight']} $thread['highlight']{/if}{if $_G['setting']['grid']['showtips']} tip="{lang title}: <strong>$thread[oldsubject]</strong><br/>{lang author}: $thread[author] ($thread[dateline])<br/>{lang show}/{lang reply}: $thread[views]/$thread[replies]" onmouseover="showTip(this)"{else} title="$thread[oldsubject]"{/if}{if $_G['setting']['grid']['targetblank']} target="_blank"{/if}>$thread[subject]</a></li>
  90.        <!--{/loop}-->
  91.        </ul>
  92.                                                          </div>
  93.                                                 </td>
  94.                                         <!--{/if}-->
  95.                                         </table>
  96.                                 </div>
  97.                         </div>
  98.                 </div>
  99.                 <!-- index four grid end -->
  100.                 <!--{/if}-->
這樣電腦端就不顯示自帶的論壇首頁四格,只讓觸屏版顯示
6 點(diǎn)
 樓主| 發(fā)表于 2023-11-19 09:27:35 |廣西| 只看Ta
N格里面內(nèi)容最好可以自定義那種,只要手機(jī)版的
664 點(diǎn)
發(fā)表于 2023-11-19 09:30:27 |浙江| 只看Ta
回帖獎(jiǎng)勵(lì) +1 個(gè)金幣
默認(rèn)自帶的手機(jī)版是基于電腦版開啟的前提下的,是自帶了的。如果不喜歡那種效果,那就需要自己選購第三方N格插件了
你這個(gè)模板,可以只要手機(jī)版么https://addon.dismall.com/plugins/k_nge.html 電腦版我有對應(yīng)的N格了
發(fā)表于 2023-11-19 09:31
29 點(diǎn)
193 個(gè)
發(fā)表于 2023-11-19 10:47:11 |江蘇| 只看Ta
  13.        <!--{else}-->
  15.        <!--{/if}-->
  28.        {eval $k = 1;}
  33.        {eval $k++;}
  34.        <!--{/loop}-->
  35.        </script>
  37.        </div>
  38.                                                         </div>
  39.                                                 </td>
  40.                                         <!--{/if}-->
  48.        <!--{/if}-->
  50.        <!--{/loop}-->
  51.                                                  </ul>
  52.                                          </div>
  53.                                         </td>
  61.        <!--{/if}-->
  63.        <!--{/loop}-->
  64.                                                  </ul>
  65.                                          </div>
  66.                                         </td>
  74.        <!--{/if}-->
  76.        <!--{/loop}-->
  77.                                                  </ul>
  78.                                          </div>
  79.                                         </td>
  88.        <!--{/if}-->
  90.        <!--{/loop}-->
  91.        </ul>
  92.                                                          </div>
  93.                                                 </td>
  94.                                         <!--{/if}-->
  95.                                         </table>
  96.                                 </div>
  97.                         </div>
  98.                 </div>
  100.                 <!--{/if}-->
謝謝您,晚了點(diǎn),買了插件實(shí)現(xiàn)https://addon.dismall.com/plugins/k_nge.html
發(fā)表于 2023-11-19 11:37
發(fā)表于 2024-8-23 09:17:40 |江蘇| 只看Ta
我只是看到拿金幣的
145 點(diǎn)
90 個(gè)
發(fā)表于 2024-8-23 09:40:15 |馬來西亞| 只看Ta
差點(diǎn)走寶了,原來還有金幣拿
版主
6 個(gè)
發(fā)表于 2024-8-23 09:59:28 |江蘇| 只看Ta
拿完走人
17 點(diǎn)
36 個(gè)
發(fā)表于 2024-8-23 21:04:50 |四川| 只看Ta
我只是看到拿金幣的
GMT+8, 2026-4-14 17:06 , Processed in 0.060235 second(s), 16 queries , Redis On.
