查看: 1982|回復: 3
[求助] 頁面底部的查詢時間變長了要如何優(yōu)化?另外看了下慢查詢記錄里有個表請求時間很久是缺少索引嗎?
3 點
67 個
發(fā)表于 2023-12-11 19:12:56 |福建| 只看樓主 |倒序瀏覽 |閱讀模式
比如Dismall網(wǎng)站底部的處理時間是0.03秒左右,我們之前最快也差不多,現(xiàn)在變成了0.07秒左右,不知道是哪里設置沒優(yōu)化好還是數(shù)據(jù)庫問題,已經(jīng)啟用Redis
另外慢查詢里發(fā)現(xiàn)兩個表的時間比較久,表是innodb引擎,請問是那里問題?
  1. # Time: 2023-12-11T10:52:54.556741Z
  2. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 364698
  3. # Query_time: 4.171622  Lock_time: 0.000000 Rows_sent: 6  Rows_examined: 629667
  4. SET timestamp=1702291974;
  5. SELECT DISTINCT t.*, ti.attachment as attachmenturl, ti.remote
  6.                         FROM `pre_forum_thread` t
  7.                          INNER JOIN `pre_forum_threadimage` ti ON t.tid=ti.tid WHERE t.readperm='0'
  8.                          AND t.fid IN ('37','36','2') AND t.isgroup='0'
  9.                         AND t.displayorder>='0'
  10.                         ORDER BY t.dateline DESC
  11.                         LIMIT 0,6;
  12. # Time: 2023-12-11T10:52:55.744347Z
  13. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 364782
  14. # Query_time: 1.078406  Lock_time: 0.000000 Rows_sent: 6  Rows_examined: 156282
  15. SET timestamp=1702291975;
  16. SELECT DISTINCT t.*, ti.attachment as attachmenturl, ti.remote
  17.                         FROM `pre_forum_thread` t
  18.                          INNER JOIN `pre_forum_threadimage` ti ON t.tid=ti.tid WHERE t.readperm='0'
  19.                          AND t.fid IN ('37') AND t.isgroup='0'
  20.                         AND t.displayorder>='0'
  21.                         ORDER BY t.dateline DESC
  22.                         LIMIT 0,6;
  23. # Time: 2023-12-11T10:54:16.983359Z
  24. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 366522
  25. # Query_time: 1.254606  Lock_time: 0.000000 Rows_sent: 10  Rows_examined: 397061
  26. SET timestamp=1702292056;
  27. SELECT DISTINCT t.*
  28.                         FROM `pre_forum_thread` t
  29.                          WHERE t.readperm='0'
  30.                          AND t.fid IN ('82','40','41','44','43','45','63','39','87','64','51','52','88','56','48','57','59','61','60','66','67','68','70','71','72','74','76','93','79') AND t.isgroup='0'
  31.                         AND t.displayorder>='0'
  32.                         ORDER BY t.dateline DESC
  33.                         LIMIT 0,10;
  34. # Time: 2023-12-11T10:54:18.474966Z
  35. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 366548
  36. # Query_time: 1.226406  Lock_time: 0.000000 Rows_sent: 10  Rows_examined: 397061
  37. SET timestamp=1702292058;
  38. SELECT DISTINCT t.*
  39.                         FROM `pre_forum_thread` t
  40.                          WHERE t.readperm='0'
  41.                          AND t.fid IN ('37','36','2') AND t.special IN ('0') AND t.isgroup='0'
  42.                         AND t.displayorder>='0'
  43.                         ORDER BY t.dateline DESC
  44.                         LIMIT 0,10;
  45. # Time: 2023-12-11T10:56:56.033320Z
  46. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 369432
  47. # Query_time: 1.996411  Lock_time: 0.001000 Rows_sent: 3  Rows_examined: 397108
  48. SET timestamp=1702292216;
  49. SELECT DISTINCT t.*, ti.attachment as attachmenturl, ti.remote
  50.                         FROM `pre_forum_thread` t
  51.                          INNER JOIN `pre_forum_threadimage` ti ON t.tid=ti.tid WHERE t.readperm='0'
  52.                          AND t.fid IN ('48') AND t.isgroup='0' AND t.dateline >= '1701687413'
  53.                         AND t.displayorder>='0'
  54.                         ORDER BY t.recommends DESC
  55.                         LIMIT 0,3;
  56. # Time: 2023-12-11T10:57:06.324541Z
  57. # User@Host: root[root] @ localhost [127.0.0.1]  Id: 369624
  58. # Query_time: 2.121604  Lock_time: 0.000000 Rows_sent: 3  Rows_examined: 397222
  59. SET timestamp=1702292226;
  60. SELECT DISTINCT t.*, ti.attachment as attachmenturl, ti.remote
  61.                         FROM `pre_forum_thread` t
  62.                          INNER JOIN `pre_forum_threadimage` ti ON t.tid=ti.tid WHERE t.readperm='0'
  63.                          AND t.fid IN ('51','52','88') AND t.isgroup='0' AND t.dateline >= '1701687424'
  64.                         AND t.displayorder>='0'
  65.                         ORDER BY t.recommends DESC
  66.                         LIMIT 0,3;
我知道答案 回答被采納將會獲得1 貢獻 已有3人回答
434 點
發(fā)表于 2023-12-11 20:09:56 |河南| 只看Ta
0.07 已經(jīng)很快了!不影響正常訪問!  沒必要費七八力的再去做優(yōu)化!
緩存 也要有訪問過 才有作用! 隨著數(shù)據(jù)庫的增大, 硬盤io的壓力增大, 速度肯定會越來越慢的!
3 點
67 個
 樓主| 發(fā)表于 2023-12-11 20:19:19 |福建| 只看Ta
天外飄仙 發(fā)表于 2023-12-11 20:09
緩存 也要有訪問過 才有作用! 隨著數(shù)據(jù)庫 ...
因之前也是0.03秒左右,過幾天就增加了,所以想知道是哪里問題,跟哪些設置有關系
434 點
發(fā)表于 2023-12-11 20:42:18 |河南| 只看Ta
數(shù)碼達人 發(fā)表于 2023-12-11 20:19
因之前也是0.03秒左右,過幾天就增加了,所以想知道是哪里問題,跟哪些設置有關系 ...
你多刷新幾次看看呢!
除非慢查詢 頻繁出現(xiàn), 偶爾出現(xiàn)是正常的! cpu爆表的時候  很容易出現(xiàn)慢查詢! 隨著訪問量的增大, cpu和硬盤io的 可用性能肯定會越來越少!
dz的sql優(yōu)化 已經(jīng)非常好了!  我 50G的數(shù)據(jù)庫 ssd硬盤 沒啥壓力! 如果機械硬盤肯定就不行了! 機械硬盤io不行
GMT+8, 2026-4-14 17:06 , Processed in 0.054436 second(s), 14 queries , Redis On.
