- 積分
- 99
- 金幣
- 4 個(gè)
- 社區(qū)幣
- 0 元
- 貢獻(xiàn)
- 0 點(diǎn)
- 金幣
- 4 個(gè)
2420修復(fù)后臺(tái)“允許用戶編輯帖子時(shí)刪除帖子”的默認(rèn)選項(xiàng)與描述不一致的問(wèn)題
[color=rgb(0, 180, 0) !important]+1 [color=rgb(217, 43, 47) !important]-1 upload/install/data/install_data.sql[size=1em] 100644 -> 100644
| @@ -314,7 +314,7 @@ INSERT INTO pre_common_setting VALUES ('ec_mincredits','0'); | 314 | | INSERT INTO pre_common_setting VALUES ('ec_ratio','0'); | 315 | 315 | INSERT INTO pre_common_setting VALUES ('editedby','1'); | 316 | 316 | INSERT INTO pre_common_setting VALUES ('editoroptions','6'); | 317 | | INSERT INTO pre_common_setting VALUES ('editperdel', '1'); | | 317 | INSERT INTO pre_common_setting VALUES ('editperdel', '0'); | 318 | 318 | INSERT INTO pre_common_setting VALUES ('edittimelimit',''); | 319 | 319 | INSERT INTO pre_common_setting VALUES ('exchangemincredits','100'); | 320 | 320 | INSERT INTO pre_common_setting VALUES ('extcredits',''); |
已安裝的論壇,這個(gè)怎么修復(fù)?我論壇是跟著gitee的修復(fù)一起同步的
我知道答案
回答被采納將會(huì)獲得 1 貢獻(xiàn) 已有1人回答
