12下一頁(yè)
查看: 9696|回復(fù): 11
discuz x 3.4 用戶(hù)表 主表 存檔表 數(shù)據(jù)合并教程!
83
功行圓滿(mǎn)
23 點(diǎn)
351 個(gè)
發(fā)表于 2020-5-19 19:59:49 |英國(guó)| 只看樓主 |倒序?yàn)g覽 |閱讀模式
1,登錄后臺(tái),工具,計(jì)劃任務(wù),取消勾選 每日用戶(hù)表優(yōu)化
2,關(guān)閉站點(diǎn),備份數(shù)據(jù)庫(kù),如果可以,全站備份更好
3,不要手賤去點(diǎn) 后臺(tái),站長(zhǎng),用戶(hù)表優(yōu)化
4,打開(kāi)你的MYSQL管理工具,比如 phpMyAdmin
幾個(gè)受影響需要更改的表
  1. pre_common_member
  2. pre_common_member_archive
  3. pre_common_member_count
  4. pre_common_member_count_archive
  5. pre_common_member_field_forum
  6. pre_common_member_field_forum_archive
  7. pre_common_member_field_home
  8. pre_common_member_field_home_archive
  9. pre_common_member_profile
  10. pre_common_member_profile_archive
  11. pre_common_member_status
  12. pre_common_member_status_archive
5,看一下上面數(shù)據(jù)庫(kù)中的幾個(gè)表,受影響了幾個(gè),受影響的都要修改
打開(kāi)  pre_common_member_archive
刪除重復(fù)內(nèi)容
  1. ALTER IGNORE TABLE pre_common_member_archive ADD UNIQUE INDEX(`uid`)
把 pre_common_member_archive 內(nèi)容復(fù)制到 pre_common_member
  1. insert into pre_common_member select * from pre_common_member_archive
再刪除主表重復(fù)內(nèi)容,清空存檔表內(nèi)容
上面做完基本就沒(méi)事了,有強(qiáng)迫癥的可以刪除帶有Archive的空表,備份的bak表都可以刪除
刪除帶有Archive的空表,更新緩存的時(shí)候出現(xiàn)這個(gè)錯(cuò)誤,而且注冊(cè)不了(在注冊(cè)的最后一步會(huì)出現(xiàn)不跳轉(zhuǎn)的情況)
  1. (1146) Table 'db_web411070.common_member_archive' doesn't existSELECT COUNT(*) FROM common_member_archive
在站長(zhǎng)—數(shù)據(jù)庫(kù)—升級(jí)(Discuz! 數(shù)據(jù)庫(kù)升級(jí) - 請(qǐng)將數(shù)據(jù)庫(kù)升級(jí)語(yǔ)句粘貼在下面:)中執(zhí)行語(yǔ)句
為了數(shù)據(jù)安全執(zhí)行該語(yǔ)句前建議備份數(shù)據(jù)
  1. DELETE FROM `pre_common_setting` WHERE `skey` = 'membersplit';
后臺(tái),站長(zhǎng),數(shù)據(jù)庫(kù),升級(jí)
  1. insert into pre_common_member select * from pre_common_member_archive;
  2. insert into pre_common_member_count select * from pre_common_member_count_archive;
  3. insert into pre_common_member_field_forum select * from pre_common_member_field_forum_archive;
  4. insert into pre_common_member_field_home select * from pre_common_member_field_home_archive;
  5. insert into pre_common_member_profile select * from pre_common_member_profile_archive;
  6. insert into pre_common_member_status select * from pre_common_member_status_archive;
以上六條的意思就是把六個(gè)存檔表中的東西合并到主表中。
然后再使用如下升級(jí)數(shù)據(jù)庫(kù):
  1. TRUNCATE TABLE  `pre_common_member_archive`;
  2. TRUNCATE TABLE  `pre_common_member_count_archive`;
  3. TRUNCATE TABLE  `pre_common_member_field_forum_archive`;
  4. TRUNCATE TABLE  `pre_common_member_field_home_archive`;
  5. TRUNCATE TABLE  `pre_common_member_profile_archive`;
  6. TRUNCATE TABLE  `pre_common_member_status_archive`;
以上六條的意思就是把六個(gè)存檔表數(shù)據(jù)全部清空。
24 個(gè)
發(fā)表于 2020-5-20 10:28:10 |廣東| 只看Ta
如果有文件執(zhí)行就好了,改數(shù)據(jù)庫(kù)不太懂
17 個(gè)
發(fā)表于 2020-5-21 11:16:44 |江蘇| 只看Ta
果斷MARK,前十有我必火!
17 個(gè)
發(fā)表于 2020-8-21 20:55:29 |湖北| 只看Ta
可以跟舊論壇的表合并嗎
功行圓滿(mǎn)
23 點(diǎn)
351 個(gè)
 樓主| 發(fā)表于 2020-8-22 04:15:14 |英國(guó)| 只看Ta
xiaojie83 發(fā)表于 2020-8-21 11:55
可以跟舊論壇的表合并嗎
同一discuz x 3.4程序版本才可合并
17 個(gè)
發(fā)表于 2020-8-22 16:53:08 |湖北| 只看Ta
allthebest 發(fā)表于 2020-8-22 04:15
都是3.4版本的
功行圓滿(mǎn)
23 點(diǎn)
351 個(gè)
 樓主| 發(fā)表于 2020-8-22 17:19:37 |英國(guó)| 只看Ta
這方法只適用于一個(gè)discuz x 3.4 用戶(hù)表 主表 存檔表 數(shù)據(jù)合并,不支持兩個(gè)discuz x 3.4論壇用戶(hù)表 主表 存檔表合并。
發(fā)表于 2021-10-21 12:14:11 |江蘇| 只看Ta
樓主你好,我的情況就是你說(shuō)的 手賤 點(diǎn)了后臺(tái)的站長(zhǎng)  用戶(hù)數(shù)據(jù)表優(yōu)化,可否有償幫忙解決一下,我的VX:jingjianchun  加我一下
功行圓滿(mǎn)
23 點(diǎn)
351 個(gè)
 樓主| 發(fā)表于 2021-10-21 18:12:58 |英國(guó)| 只看Ta
小景 發(fā)表于 2021-10-21 03:14
樓主你好,我的情況就是你說(shuō)的 手賤 點(diǎn)了后臺(tái)的站長(zhǎng)  用戶(hù)數(shù)據(jù)表優(yōu)化,可否有償幫忙解決一下,我的VX:jing ...
關(guān)閉用戶(hù)數(shù)據(jù)表優(yōu)化,更新緩存,即可。
17 個(gè)
發(fā)表于 2024-3-31 23:29:40 |山東| 只看Ta
X3.5一樣嗎?能出個(gè)3.5的教程嗎?
GMT+8, 2026-4-14 17:06 , Processed in 0.046862 second(s), 11 queries , Redis On.
